tools:digitalfabrication:3dprinters:leftcr10 [2020/09/20 18:39] jabelone [Modifications / Repair History] |
— (current) | ||
- | ==== Left CR-10 ==== | ||
- | {{:tools:cr-10.jpg?300&direct}} | ||
- | **Internal Address:** [[http://left-cr10.hsbne.org/]] ([[http://10.0.1.152/]]) | ||
- | **Maintainers:** Drew Spriggs and Jaimyn Mayer | ||
- | ===== Modifications / Repair History ===== | ||
- | ^ Date ^ Modified By ^ Description ^ Remediation ^ Cost ^ | ||
- | | xx/08/2020 | Scott and Jaimyn | Swapped the mainboards around on the printers to get them up and running again (mainly Scott). | 1hr of time | | ||
- | | 22/08/2020 | Jaimyn | Bed was found to be not level and incorrect filament loaded. | Loaded new roll of PLA and flushed out hotend. Levelled bed by adjusting the screws on each corner. | 1hr of time | | ||
- | | 17/09/2020 | Jaimyn | Bed was found to be not level and OctoPrint was offline. | Fixed OctoPrint by reseating all of the power/network cables and changing DNS over to new IP address. Added static IP. Levelled bed by adjusting the screws on each corner. | 2hrs of time | |
