tools:digitalfabrication:3dprinters:upmini [2020/04/11 12:01] 127.0.0.1 external edit |
tools:digitalfabrication:3dprinters:upmini [2021/10/14 13:12] davidjericho removed |
- | ==== Up Mini ==== | + | <WRAP column third> |
+ | {{:tools:digitalfabrication:3dprinters:upmini.jpg?400&nolink}} | ||
+ | ====== Up Mini V1 ====== | ||
+ | | Aliases | Up Mini | | ||
+ | | Other References |<WRAP> | ||
+ | //[[https://snipe.hsbne.org/|Asset Register]]// | ||
- | {{:tools:digitalfabrication:3dprinters:upmini.jpg?400|}} | + | //[[https://xero.com/|Xero Asset]]// |
- | **Internal Address:** Accessed via the PC next to it. | + | //[[https://portal.hsbne.org/|Portal]]// |
- | **Maintainers:** Brendan Halliday | + | [[https://forum.hsbne.org/search?q=up%20mini|Forum Posts]] |
+ | </WRAP>| | ||
+ | | Official Maintainer | Brendan Halliday | | ||
+ | <WRAP clear></WRAP> | ||
+ | ===== Current Status ===== | ||
+ | <WRAP warning half round> | ||
+ | === Not Working === | ||
+ | Machine is not working as expected, it has been taken off site to be maintained due to a nozzle clog. | ||
+ | ===== Usage ===== | ||
+ | <WRAP half round info> | ||
+ | **This machine is <wrap hi>generally available</wrap> to use.** | ||
+ | ==== Guidelines ==== | ||
+ | <WRAP half round help> | ||
+ | [[:howto:upmini|How to use the UP Mini]] | ||
+ | <WRAP column half> | ||
+ | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&200|}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
+ | | Required | {{:resources:ppe-wearhandprotection.gif?nolink&200|}} | These absolutely must be used while removing prints from the printer bed. | | ||
+ | ^ Name ^ Value ^ | ||
+ | | Printing Area | 100x100x100mm | | ||
+ | {{ :tools:digitalfabrication:3dprinters:up_mini_user_manual.pdf | Manual }} | ||
+ | === Manufacturer === | ||
+ | * Tiertime | ||
+ | === Reseller === | ||
+ | * 3dprintergear | ||
+ | * 3dprintsuperstore | ||
+ | === Known Identical Models === | ||
+ | ^ Date ^ Description ^ Workaround ^ Proposed Remediation | | ||
+ | | Jun 2019 | UP! Studio Software generates print jobs that fail after several layers. | Use the UP! 2.18 Software instead. | Uninstall UP! Studio from PC.| | ||
+ | | Jun 2018 | Brendan Halliday | Nozzle replaced. | Old nozzle was clogged with debris that could not be shifted with soaking in ABS. It was binned. | $25 AUD | | ||
+ | | {{ :tools:digitalfabrication:3dprinters:upmini-scraper.png?nolink&100 |}} | Core Tool | **Bed Scraper** \\ Bed scraper for removing prints from perfboard. | Side of Machine | N/A | | ||
+ | | {{ :tools:digitalfabrication:3dprinters:upmini-benchhook.jpg?nolink&100 |}} | Core Tool | **Bench Hook** \\ Bench Hook for supporting the removed Up Mini perfboard while print is being removed.| Side of Machine | N/A | | ||
+ | | {{:tools:digitalfabrication:3dprinters:upmini_nozzlewrench.jpg?nolink&100}} | Maintenance tool | **Nozzle Wrench** \\ Wrench for undoing nozzle. Only to be used by tool maintainer(s). Always make sure nozzle is at extrusion temperature before using. | Side of Machine | N/A | | ||
+ | | {{:tools:digitalfabrication:3dprinters:z-abs-blackv2.png?nolink&100]]}} | Filament | **Zortrax ABS Filament** \\ Zortrax or UP! Branded ABS Filament | Behind the Up Mini | https://www.3dprintergear.com.au/zortrax-black-z-abs-v2-0.8kg | | ||
+ | | {{:tools:digitalfabrication:3dprinters:upmini_perfboard.jpg?100|nolink&}} | Printing Surface | **Up Mini Perfboard** \\ Printing surface for the printer. | Behind the Up Mini | https://www.3dprintingsolutions.com.au/Store/Australia/rvdsfpid/perfboard-for-up-3d-printers-85/rvdsfcatid/printing-surfaces-175 | | ||
+ | ===== Maintenance ===== | ||
+ | ^ Interval ^ Task ^ | ||
+ | | Monthly | Filament extrusion - to ensure nozzle is clean. | | ||
+ | | Monthly | Bed clean - Scrape the beds clean | | ||
+ | ===== RACI ===== | ||
+ | <WRAP column third> | ||
+ | | Modification and Repairs | - | AC | RAC | I | I | I | R | | ||
+ | ^ Ref / ID ^ Pre-Mitigation |||^ Mitigations / Warnings / Remedies ^ Post Mitigation |||^ | ||
+ | ^ ::: ^ Risk ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ ::: ^ Risk Severity ^ Risk Likelyhood ^ Risk Level ^ Acceptable to Proceed ^ | ||
+ | | 0001 | Fire | Tolerable | Improbable | 4 | Induction to train users in correct usage | Low | Improbable | 1 | | ||
