tools:digitalfabrication:3dprinters:upmini [2020/09/27 22:13] nogthree |
tools:digitalfabrication:3dprinters:upmini [2021/10/14 13:12] davidjericho removed |
Line 21: | Line 21: | ||
- | <WRAP safety half round> | + | <WRAP warning half round> |
- | === Working === | + | === Not Working === |
- | Machine is working as expected. | + | Machine is not working as expected, it has been taken off site to be maintained due to a nozzle clog. |
- | <WRAP half round info > | + | <WRAP half round info> |
**This machine is <wrap hi>generally available</wrap> to use.** | **This machine is <wrap hi>generally available</wrap> to use.** | ||
+ | <WRAP half round help> | ||
[[:howto:upmini|How to use the UP Mini]] | [[:howto:upmini|How to use the UP Mini]] | ||
Line 52: | Line 57: | ||
- | {{ :tools:digitalfabrication:upmini.pdf | Manual }} | + | {{ :tools:digitalfabrication:3dprinters:up_mini_user_manual.pdf | Manual }} |
Line 81: | Line 86: | ||
^ Image ^ Category ^ Accessory Name & Notes ^ Location ^ Buy from ^ | ^ Image ^ Category ^ Accessory Name & Notes ^ Location ^ Buy from ^ | ||
- | | {{:tools:digitalfabrication:3dprinters:upmini_nozzlewrench.jpg?nolink&100}} | Maintenance tool | **Nozzle Wrench** \\ Wrench for undoing nozzle. Always make sure nozzle is at extrusion temperature before using. | Side of Machine | N/A | | + | | {{ :tools:digitalfabrication:3dprinters:upmini-scraper.png?nolink&100 |}} | Core Tool | **Bed Scraper** \\ Bed scraper for removing prints from perfboard. | Side of Machine | N/A | |
- | | {{ :tools:digitalfabrication:3dprinters:upmini-scraper.png?nolink&100 |}} | Core Tool | **Bed Scraper** \\ Bed scraper for removing prints from perfboard.. | Side of Machine | N/A | | + | | {{ :tools:digitalfabrication:3dprinters:upmini-benchhook.jpg?nolink&100 |}} | Core Tool | **Bench Hook** \\ Bench Hook for supporting the removed Up Mini perfboard while print is being removed.| Side of Machine | N/A | |
+ | | {{:tools:digitalfabrication:3dprinters:upmini_nozzlewrench.jpg?nolink&100}} | Maintenance tool | **Nozzle Wrench** \\ Wrench for undoing nozzle. Only to be used by tool maintainer(s). Always make sure nozzle is at extrusion temperature before using. | Side of Machine | N/A | | ||
