tools:digitalfabrication:3dprinters:upmini [2020/09/27 22:08] nogthree [Modifications / Repair History] |
— (current) | ||
- | <WRAP column third> | ||
- | {{:tools:digitalfabrication:3dprinters:upmini.jpg?400&nolink}} | ||
- | ====== Up Mini V1 ====== | ||
- | | Aliases | Up Mini | | ||
- | | Other References |<WRAP> | ||
- | //[[https://snipe.hsbne.org/|Asset Register]]// | ||
- | //[[https://xero.com/|Xero Asset]]// | ||
- | //[[https://portal.hsbne.org/|Portal]]// | ||
- | [[https://forum.hsbne.org/search?q=up%20mini|Forum Posts]] | ||
- | </WRAP>| | ||
- | | Official Maintainer | Brendan Halliday | | ||
- | <WRAP clear></WRAP> | ||
- | ===== Current Status ===== | ||
- | === Working === | ||
- | Machine is working as expected. | ||
- | ===== Usage ===== | ||
- | <WRAP half round info > | ||
- | **This machine is <wrap hi>generally available</wrap> to use.** | ||
- | ==== Guidelines ==== | ||
- | [[:howto:upmini|How to use the UP Mini]] | ||
- | ==== Recommended PPE ==== | ||
- | <WRAP column half> | ||
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&200|}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
- | | Required | {{:resources:ppe-wearhandprotection.gif?nolink&200|}} | These absolutely must be used while removing prints from the printer bed. | | ||
- | <WRAP clearall></WRAP> | ||
- | ===== Machine Specifications ===== | ||
- | ^ Name ^ Value ^ | ||
- | | Printing Area | 100x100x100mm | | ||
- | ===== Documents ===== | ||
- | <WRAP center round download third left> | ||
- | {{ :tools:digitalfabrication:upmini.pdf | Manual }} | ||
- | ===== Manufacturer ===== | ||
- | === Manufacturer === | ||
- | * Tiertime | ||
- | === Reseller === | ||
- | * 3dprintergear | ||
- | * 3dprintsuperstore | ||
- | === Known Identical Models === | ||
- | ===== Known Issues ===== | ||
- | ^ Date ^ Description ^ Workaround ^ Proposed Remediation | | ||
- | | Jun 2019 | UP! Studio Software generates print jobs that fail after several layers. | Use the UP! 2.18 Software instead. | Uninstall UP! Studio from PC.| | ||
- | ===== Modifications / Repair History ===== | ||
- | ^ Date ^ Modified By ^ Description ^ Remediation ^ Cost ^ | ||
- | | Jun 2018 | Brendan Halliday | Nozzle replaced. | Old nozzle was clogged with debris that could not be shifted with soaking in ABS. It was binned. | $25 AUD | | ||
- | ===== Accessories ===== | ||
- | ^ Image ^ Category ^ Accessory Name & Notes ^ Location ^ Buy from ^ | ||
- | | {{:tools:digitalfabrication:3dprinters:upmini_nozzlewrench.jpg?100|}} | Maintenance tool | **Nozzle Wrench** \\ Wrench for undoing nozzle. Always make sure nozzle is at extrusion temperature before using. | Side of Machine | N/A | | ||
- | ===== Consumables & Running Costs ===== | ||
- | | {{:tools:digitalfabrication:3dprinters:z-abs-blackv2.png?100]]}} | Filament | **Zortrax ABS Filament** \\ Zortrax or UP! Branded ABS Filament | Behind the Up Mini | https://www.3dprintergear.com.au/zortrax-black-z-abs-v2-0.8kg | | ||
- | | {{:tools:digitalfabrication:3dprinters:upmini_perfboard.jpg?100|}} | Printing Surface | **Up Mini Perfboard** \\ Printing surface for the printer. | Behind the Up Mini | https://www.3dprintingsolutions.com.au/Store/Australia/rvdsfpid/perfboard-for-up-3d-printers-85/rvdsfcatid/printing-surfaces-175 | | ||
- | ===== Maintenance ===== | ||
- | ^ Interval ^ Task ^ | ||
- | | Monthly | Filament extrusion - to ensure nozzle is clean. | | ||
- | | Monthly | Bed clean - Scrape the beds clean | | ||
- | ===== RACI ===== | ||
- | | Modification and Repairs | - | AC | RAC | I | I | I | R | | ||
- | | 0001 | Fire | Tolerable | Improbable | 4 | Induction to train users in correct usage | Low | Improbable | 1 | | ||
- | ===== Decision Register ===== | ||
- | ^ Ref / ID ^ Decision Details ^ Impact ^ Proposed Date ^ Proposed By ^ Status ^ Approved By ^ Date ^ Resulting Actions and Comments ^ | ||
- tools/digitalfabrication/3dprinters/upmini.1601208511
- by nogthree
