causes:craftpunk [2020/04/14 15:07] nogthree |
causes:craftpunk [2020/12/08 19:19] lonepiper_paula |
- | <panel> | + | <WRAP> |
- | **Current goals:** | ||
- | * Run classes | ||
- | </panel> | ||
Line 34: | Line 27: | ||
Line 39: | Line 37: | ||
+ | | Sodium Bi-Sulfite - Jewellery Pickle | {{ :causes:craftpunk:msds:sodium_bisulphate_msds_sbs-sds-english-can.pdf |MSDS}} | [[https://www.jewellerssupplies.com.au/product/26106-pickle-compound-500g?categoryId=198|AJS]] , Coles or Woolworths| ??? | | ||
+ | | Airbrush Paint | {{ :causes:craftpunk:msds:creative_pl_airbrush_colour_msds.pdf |MSDS}}| Art Suppliers | User Selected Donation | | ||
Line 45: | Line 64: | ||
Line 54: | Line 72: | ||
- causes/craftpunk
