tools:metalshop:3axismill [2021/01/01 20:44] ryan6338 [Recommended PPE] |
- | ====== Pacific FTV-2S Turret Mill ====== | + | ====== Mill, Turret - Pacific FTV-2S ====== |
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 33: | Line 34: | ||
- | ==== Recommended PPE ==== | + | How fast should I be cutting? The [[https://zero-divide.net/fswizard|Speeds and Feeds Wizard]] can give you the answer. |
- | <WRAP column> | + | <WRAP quarter round tip> |
- | | Required | {{:resources:ppe-weargoggle.gif?nolink&100|}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | + | [[howto:clean_up_coolant_spils_in_the_metalshop|How to Clean Up Coolant Spills in the Metalshop]] |
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc | | + | </WRAP> |
- | | Recommended | {{:resources:ppe-wearearprotection.gif?nolink&100|}} | We recommend hearing protection. | | + | |
- | | Warning | {{:resources:ppe-wearhandprotection.gif?nolink&100|}} | Entanglement hazard present while wearing gloves. | | + | ===== Learning ===== |
- | | Maintenance | {{:resources:ppe-disconnect.gif?nolink&100|}} | Disconnect power to the machine before performing maintenance, including wheel changes | | + | Recommended learning resources: |
+ | <WRAP half column> | ||
+ | | Required | {{ :resources:ppe-wearsafetyglasses.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | ||
+ | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | | ||
+ | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | | ||
+ | | Recommended | {{ :resources:ppe-wearearprotection.gif?nolink&100 |}} | We recommend hearing protection. | | ||
+ | | Warning | {{ :resources:ppe-wearhandprotection.gif?nolink&100 |}} | Entanglement hazard present while wearing gloves. | | ||
Line 50: | Line 66: | ||
^ Name ^ Value ^ | ^ Name ^ Value ^ | ||
- | | Attribute A | 305mm | | + | | Motor Power | 3 Phase, 415V | |
- | | Attribute B | 1600 mm x 270 mm | | + | | Spindle Style | ISO40, M16 Drawbar | |
- | | Attribute C | 3.0 hp | | + | | Spindle Speed | 50-4000RPM, Continuous | |
- | === Reseller === | + | |
- | * Mr. Re seller | + | |
Line 131: | Line 140: | ||
- tools/metalshop/3axismill
capella_ben
