tools:metalshop:3axismill [2022/09/16 13:39] capella_ben [Risk Matrix and Mitigation] |
tools:metalshop:3axismill [2023/07/19 08:11] (current) capella_ben [Current Status] |
Line 12: | Line 12: | ||
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 24: | Line 35: | ||
Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | Book an induction in Eventbrite. \\ [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | ||
+ | ===== Learning ===== | ||
Line 48: | Line 71: | ||
- | No documents are currently available for this machine. | + | <WRAP center round download third left> |
- | ===== Manufacturer ===== | + | {{ :tools:metalshop:mill_dro_manual.pdf |}} |
- | PLACEHOLDER: Document the manufacturer, things like contact person names, emails, phone numbers, product urls etc. Document the reseller we bought from, and any other sources for similar things. Delete this line. | + | <WRAP clear></WRAP> |
- | === Manufacturer === | + | ===== Manufacturer ===== |
- | * E sales@example.com | ||
- | * P 00 0000 0000 | ||
- | * [[https://www.example.com/]] | ||
- | === Reseller === | + | === Manufacturer === |
- | * Mr. Re seller | + | * The Pacific Mill is a renamed Lagun |
- | * Reseller Agencies | + | * [[https://lagun.com]] |
Line 129: | Line 151: | ||
| 0008 | Slip | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. | Minor | Unlikely | 4 | Yes | | | 0008 | Slip | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. | Minor | Unlikely | 4 | Yes | | ||
| 0009 | Respiratory/Skin Irritation | Moderate | Unlikely | 6 | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. | Minor | Unlikely | 4 | Yes | | | 0009 | Respiratory/Skin Irritation | Moderate | Unlikely | 6 | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. | Minor | Unlikely | 4 | Yes | | ||
- | | 0010 | Inhaliation of Fumes | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | + | | 0010 | Inhaliation of Fumes | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Fans are provided top assist in ventilation. \\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | |
| 0011 | Laceration/Dismemberment | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | | 0011 | Laceration/Dismemberment | Major | Possible | 12 | Induction to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE. | Minor | Unlikely | 4 | Yes | | ||
| 0012 | Burn from workpiece | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure adequate coolant is used.\\ Require assessing workpiece temperature before handling. | Insignificant | Unlikely | 2 | Yes | | | 0012 | Burn from workpiece | Moderate | Possible | 9 | Induction to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure adequate coolant is used.\\ Require assessing workpiece temperature before handling. | Insignificant | Unlikely | 2 | Yes | |
- tools/metalshop/3axismill.1663299560
