tools:metalshop:3axismill [2021/01/01 21:54] ryan6338 [Recommended PPE] |
tools:metalshop:3axismill [2023/07/19 08:11] (current) capella_ben [Current Status] |
- | === Working === | ||
+ | === Working === | ||
+ | </WRAP>*/ | ||
+ | === Usable === | ||
+ | </WRAP>*/ | ||
+ | === Out of Order === | ||
Line 33: | Line 34: | ||
- | ==== Recommended PPE ==== | + | How fast should I be cutting? The [[https://zero-divide.net/fswizard|Speeds and Feeds Wizard]] can give you the answer. |
+ | ===== Learning ===== | ||
- | | Required | {{:resources:ppe-weargoggle.gif?nolink&100|}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | | + | | Required | {{ :resources:ppe-wearsafetyglasses.gif?nolink&100 |}} | Always wear AS/NZS 1337.1 compliant safety glasses while operating this machine. | |
- | | Required | {{:resources:ppe-wearenclosedshoes.gif?nolink&100|}} | Enclosed shoes are required, no open sandals, thongs etc | | + | | Required | {{ :resources:ppe-wearenclosedshoes.gif?nolink&100 |}} | Enclosed shoes are required, no open sandals, thongs etc | |
- | | Recommended | {{:resources:ppe-wearearprotection.gif?nolink&100|}} | We recommend hearing protection. | | + | | Required | {{ :resources:ppe-hair.gif?nolink&100 |}} | Restrain hair while operating machine | |
- | | Warning | {{:resources:ppe-wearhandprotection.gif?nolink&100|}} | Entanglement hazard present while wearing gloves. | | + | | Recommended | {{ :resources:ppe-wearearprotection.gif?nolink&100 |}} | We recommend hearing protection. | |
- | | Maintenance | {{:resources:ppe-disconnect.gif?nolink&100|}} | Disconnect power to the machine before performing maintenance, including wheel changes | | + | | Warning | {{ :resources:ppe-wearhandprotection.gif?nolink&100 |}} | Entanglement hazard present while wearing gloves. | |
Line 57: | Line 71: | ||
- | === Reseller === | + | |
- | * Mr. Re seller | + | |
Line 133: | Line 140: | ||
- tools/metalshop/3axismill.1609502086
- by ryan6338
