Next revision
tools:metalshop:bandsaw [2021/10/06 21:10]
ryan6338 [Guidelines]
tools:metalshop:bandsaw [2023/03/07 20:05] (current)
capella_ben [Usage]
Line 4: Line 4:
 <WRAP column twothirds>​ <WRAP column twothirds>​
 ====== Bandsaw, Horizontal - Hafco BS-7DS ====== ====== Bandsaw, Horizontal - Hafco BS-7DS ======
-| Aliases | - | +| Aliases ​             | -        ​
-| Other References |<​WRAP> ​ +| Other References ​    ​| <​WRAP> ​ //​[[https://​snipe.hsbne.org/​|Asset Register]]// ​   //​[[https://​xero.com/​|Xero Asset]]// ​   //​[[https://​portal.hsbne.org/​|Portal]]// ​   [[https://​forum.hsbne.org/​c/​cause-effect/​metalworking/​13| Metalworking Forum]] ​ </​WRAP> ​
-//​[[https://​snipe.hsbne.org/​|Asset Register]]//​ +| Official Maintainer ​ Phil Juric        ​|
-//​[[https://​xero.com/​|Xero Asset]]// +
-//​[[https://​portal.hsbne.org/​|Portal]]//​ +
-[[https://​forum.hsbne.org/​c/​cause-effect/​metalworking/​13| Metalworking Forum]] +
-</​WRAP>​| +
-| Official Maintainer | Dave Seff |+
 </​WRAP>​ </​WRAP>​
 <WRAP clear></​WRAP>​ <WRAP clear></​WRAP>​
 ===== Current Status ===== ===== Current Status =====
 <WRAP safety half round> <WRAP safety half round>
 === Working === === Working ===
 Machine is working as expected. Machine is working as expected.
 </​WRAP>​ </​WRAP>​
 +/*<WRAP warning half round>
 +=== Usable ===
 +Machine has some issue but is usable. please provide summary here
 +</​WRAP>​*/​
 +/*<WRAP danger half round>
 +=== Out of Order ===
 +Machine is non functional.
 +</​WRAP>​*/​
 ===== Usage ===== ===== Usage =====
Line 31: Line 31:
 </​WRAP>​ </​WRAP>​
-Book an induction in Eventbrite. \\ [[https://​www.eventbrite.com/​d/australia--south-brisbane/​hsbne-inc-bandsaw/?page=1]] +Book an induction in Eventbrite. \\ [[https://​www.eventbrite.com/​cc/metalshop-inductions-804979]]
-==== Personal Protective Equipment ====+
 +This machine is a part of the Drill Press, Linishers and Vertical ​bandsaw ​induction.
 +<WRAP quarter round tip>
 +[[howto:​clean_up_coolant_spils_in_the_metalshop|How to Clean Up Coolant Spills in the Metalshop]]
 +</​WRAP>​
 +===== Personal Protective Equipment ​=====
 <WRAP half column> <WRAP half column>
Line 74: Line 81:
 ===== Known Issues ===== ===== Known Issues =====
-^ Date ^ Description ^ Workaround ^ Proposed Remediation | +^ Date      ^ Description ​               ^ Workaround ​                  ​^ Proposed Remediation ​                       ^
 +| 9/​8/​2022 ​ | Main On/Off Sitch failure ​ | None                         | Replace the switch - Electrician required ​  |
 +| 9/​8/​2022 ​ | Interlock Failure ​         | Interlock has been disabled ​ | Replace the interlock microprocessor board  ​|
 ===== Modifications / Repair History ===== ===== Modifications / Repair History =====
Line 83: Line 92:
 | 08/​12/​2020 ​ | Ryan Marple ​   | All bandsaw blades dull             | Purchased 2 new bi-metal blades ​                       | $110  | | 08/​12/​2020 ​ | Ryan Marple ​   | All bandsaw blades dull             | Purchased 2 new bi-metal blades ​                       | $110  |
 | 08/​12/​2020 ​ | Ryan Marple ​   | Fasteners holding cover require different tools to open | Replaced fasteners with wing screws | $20 | | 08/​12/​2020 ​ | Ryan Marple ​   | Fasteners holding cover require different tools to open | Replaced fasteners with wing screws | $20 |
 +| 04/​01/​2022 ​ | Dave Seff    | Repaired water damaged interlock ​     | Replaced contactor ​                                    | $70   |
Line 123: Line 133:
-^ Ref / ID  ^ Pre-Mitigation ​                                                          ​|||^ Mitigations / Warnings / Remedies ​        ^ Post Mitigation ​                                                        ​|||| +^ Ref / ID  ^ Pre-Mitigation ​                                                             |||^ Mitigations / Warnings / Remedies ​        ^ Post Mitigation ​                                                        ​||||
-| :::       ^ Risk                      ^ Risk Severity ​ ^ Risk Likelyhood ​ ^ Risk Level  | :::        ^ Risk Severity ​   ^ Risk Likelyhood ​ ^ Risk Level  ^ Acceptable to Proceed ​ ^ +| :::       ^ Risk                         ​^ Risk Severity ​ ^ Risk Likelyhood ​ ^ Risk Level  | :::        ^ Risk Severity ​   ^ Risk Likelyhood ​ ^ Risk Level  ^ Acceptable to Proceed ​ ^
-| 0001      | Projectile ​               ​Intolerable ​   ​| ​Probable ​        | 12          | Induction required. \\ Require use of appropriate PPE                                                            ​Low              ​| Possible ​        | 2           | Yes                    | +| 0001      | Death                        ​Severe ​        | Possible ​        | 15          | Induction to train users in correct usage. ​        | Severe ​          | Very Unlikely ​   ​| ​5           | Yes                    |
-0002      | Entanglement ​             Intolerable ​   ​Probable ​        | 12          | Induction ​required. \\ Discourage glove use during operation. \\ Prohibit ​long hair & jewellery                  ​Low              ​| Possible ​        ​| ​          | Yes                    | +| 0002      | Electric Shock               | Major          | Unlikely ​        ​| 8           | Induction to train users in correct usage.\\ Ensure power cables are properly connected and off the floor.\\ Cables are tested and tagged and inspected for damage. ​        | Minor            | Very Unlikely ​   | 2           | Yes                    |
-0003      | Laceration/​Dismemberment ​ Intolerable ​   ​| Possible ​        ​| ​11          | Induction ​required. \\ Require use of appropriate PPE.                                                             ​Low              ​Improbable ​                | Yes                    | +| 0003      | Noise                        | Moderate ​      | Likely ​          | 12          | Train users to wear hearing protection. ​        | Insignificant ​   | Unlikely ​        | 2           | Yes                    |
-0004      ​| ​Heat burn from workpiece ​ Undesirable ​   ​| Possible ​        ​| ​          | Induction ​required.\\ Always ​ensure coolant is working properly.\\ Feel workpiece temperature before ​grabbing it Low              ​Improbable ​                | Yes                    |+| 0004      | Tripping Hazard ​             | Moderate ​      | Possible ​        | 9           | Train users to maintain a clean working area.\\ Keep all cables off the ground and secured out of the way        ​Insignificant ​   | Unlikely ​        | 2           | Yes                    |
 +| 0005      | Insufficient Lighting ​       | Minor          ​| Possible ​        | 6           | Turn on shop lights.\\ Open metal-shop doors for natural lighting. ​        | Insignificant ​   | Unlikely ​        | 2           | Yes                    |
 +0006      | Entanglement ​                ​Major          ​Possible ​        | 12          | Induction ​to train users in correct usage.\\ Remove any possible entanglement items such as long sleeves, gloves, watches, jewellery, etc.\\ Tie back long hair.        ​Minor            | Unlikely ​        | 4           | Yes                    |
 +| 0007      | Slip                         | Major          ​| Possible ​        ​| ​12          | Induction to train users in correct usage.\\ Train users in correct use of coolant to avoid spilling on the floor. ​        | Minor            | Unlikely ​        | 4           | Yes                    |
 +0008      | Respiratory/​Skin Irritation ​ | Moderate ​      | Unlikely ​        | 6           | Induction to train users in correct usage.\\ Train users in the risks related to metalworking fluids. ​        | Minor            | Unlikely ​        | 4           | Yes                    |
 +| 0009      | Inhaliation of Fumes         | Moderate ​      | Possible ​        | 9           | Induction to train users in correct usage.\\ Open metal-shop door to allow ventilation.\\ Fans are provided top assist in ventilation. \\ Train users to use the appropriate type and volume of coolant.\\ Require use of appropriate PPE.   | Minor            | Unlikely ​        | 4           | Yes                    |
 +| 0010      | Laceration/​Dismemberment ​    ​Major          ​| Possible ​        ​| ​12          | Induction ​to train users in correct usage.\\ Train users to keep clear of the cutting tool and the part.\\ Require that the cutting tool is securely fixed (in the quick change tool-post or tail-stock).\\ Require use of appropriate PPE.  Minor            ​Unlikely ​                  | Yes                    |
 +0011      ​| ​Burn from workpiece ​         Moderate ​      | Possible ​        ​| ​          | Induction ​to train users in correct usage.\\ Allow parts to cool after cutting.\\ Train users to ensure ​adequate ​coolant is used.\\ Require assessing ​workpiece temperature before ​handling                                                ​Insignificant ​   ​Unlikely ​                  | Yes                    |
 </​WRAP>​ </​WRAP>​
  • tools/metalshop/bandsaw.1633518608
  • Last modified: 3 years ago
  • by ryan6338
