tools:metalshop:linisher [2021/01/07 09:13] ryan6338 |
tools:metalshop:linisher [2023/06/28 08:51] capella_ben [Documents] |
Line 3: | Line 3: | ||
Line 28: | Line 20: | ||
**This machine <wrap hi>requires induction</wrap> to use.** | **This machine <wrap hi>requires induction</wrap> to use.** | ||
- | Request an induction in the metalshop channel on the HSBNE discord server, or create a post in the metalworking section of the forums. Inductions typically run on Tuesday nights, but alternative times can be arranged upon request. | + | Book an induction on Eventbrite.\\ |
+ | [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | ||
Line 49: | Line 43: | ||
Line 83: | Line 77: | ||
Line 128: | Line 118: | ||
Line 139: | Line 138: | ||
- tools/metalshop/linisher
