tools:metalshop:linisher [2022/08/10 15:48] capella_ben [Table] |
tools:metalshop:linisher [2022/09/14 09:29] capella_ben [Table] |
Line 89: | Line 89: | ||
Line 129: | Line 126: | ||
- | | 0001 | PROJECTILE | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Require use of appropriate PPE. | Low | Possible | 2 | | + | | 0001 | PROJECTILE | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Require use of appropriate PPE. | Low | Possible | 2 | | |
- | | 0002 | ENTANGLEMENT | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Discourage Glove Use | Low | Possible | 2 | | + | | 0002 | ENTANGLEMENT | Intolerable | Probable | 8 | Induction to train users in correct usage. \\ Discourage Glove Use | Low | Possible | 2 | | |
+ | | 0003 | Dust Inhalation - Low-hazard materials | Undesirable | Probable | 8 | Provide dust extraction & encourage respirator use. | Tolerable | Improbable | 4 | | | ||
+ | | 0004 | Dust Inhalation - Hazardous materials | Intolerable | Probable | 8 | Restrict allowed grinding materials | Undesirable | Improbable | 6 | | | ||
Line 140: | Line 139: | ||
- tools/metalshop/linisher
capella_ben
