tools:metalshop:linisher [2023/06/28 08:48] capella_ben |
Line 4: | Line 4: | ||
====== Grinder, Bench, 200mm - Linishall BG6 ====== | ====== Grinder, Bench, 200mm - Linishall BG6 ====== | ||
Line 51: | Line 43: | ||
Line 81: | Line 73: | ||
Line 98: | Line 90: | ||
+ | | {{:tools:metalshop:150mm_grinding_wheel.png|}} | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | | ||
- tools/metalshop/linisher
capella_ben
