tools:metalshop:linisher [2022/08/10 15:48] capella_ben [Table] |
tools:metalshop:linisher [2023/06/28 09:00] (current) capella_ben [Consumables & Running Costs] |
Line 3: | Line 3: | ||
Line 51: | Line 43: | ||
Line 81: | Line 73: | ||
Line 98: | Line 90: | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | + | | {{:tools:metalshop:150mm_grinding_wheel.png|}} | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | |
Line 127: | Line 119: | ||
Line 138: | Line 139: | ||
- tools/metalshop/linisher.1660110536
- Last modified: 22 months ago
