tools:metalshop:linisher [2023/06/28 08:48] capella_ben [Table] |
tools:metalshop:linisher [2023/06/28 09:00] (current) capella_ben [Consumables & Running Costs] |
Line 43: | Line 43: | ||
Line 73: | Line 73: | ||
Line 90: | Line 90: | ||
+ | | {{:tools:metalshop:150mm_grinding_wheel.png|}} | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | | ||
- tools/metalshop/linisher.1687906097
