tools:metalshop:linisher [2021/08/17 23:14] ryan6338 |
Line 3: | Line 3: | ||
Line 29: | Line 21: | ||
**This machine <wrap hi>requires induction</wrap> to use.** | **This machine <wrap hi>requires induction</wrap> to use.** | ||
- | Book an induction on Eventbrite.\\ | ||
- | [[https://www.eventbrite.com/d/australia--south-brisbane/drill-press-linishers-vertical-bandsaw-induction-(hsbne-members-only)/?page=1]] | ||
- | Request an induction in the metalshop channel on the HSBNE discord server, or create a post in the metalworking section of the forums. Inductions typically run on Tuesday nights, but alternative times can be arranged upon request. | + | Book an induction on Eventbrite.\\ |
+ | [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] | ||
Line 52: | Line 43: | ||
Line 82: | Line 73: | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | + | | {{:tools:metalshop:150mm_grinding_wheel.png|}} | Grinding Wheel | [[https://www.totaltools.com.au/124868-norton-150-x-20mm-60-grit-medium-fine-grey-aluminium-oxide-grinding-wheel-66253130583|150mm x 20mm (not 25mm) Grinding Wheel]] | | Total Tools | |
Line 131: | Line 119: | ||
Line 142: | Line 139: | ||
- tools/metalshop/linisher
